RCU Forums - View Single Post - Le and wing tip mating
Old 12-22-2008 | 08:42 AM
US185Damiani's Avatar
US185Damiani
Default RE: Le and wing tip mating
Coops,
If all the tabs are correctly situated against your building board, your tip rib should be off center to the LE if it is straight. as you mentioned, once everything is trimmed and sanded, this will give you the washout you need.
