Retract Problem
Can anyone please tell me if it will cause a problem slightly undoing the cylinder cap on an air retract cylinder?
I have a problem with the inner nipple coming out the side fouling and need to rotate 270 degrees to get clearance. I thought about mechanically moving the cylinder through 180 degrees then loosening the cap by 1/4 turn.
Would this cause a leak?
