RCU Forums - View Single Post - Best prop for tt pro36?
Old 06-11-2003 | 04:54 PM
f2racer
Default Best prop for tt pro36?
I use an 11x3 on my Uproar 40 with amazing results. Definitely unlimited vertical. Hover and vertical pull outs without issue. I've also put an 10x5 on the same setup which gives it less thrust more speed (less fun), but tops out at about the same rpm. Haven't tried a 10x4, but if it gained another thousand rpm or so, it may take similar thrust to the 11x3...
Enjoy!
