ORIGINAL: madmodelman
Yes Sandor, Sprint. I downloaded your instructions for retract installation but could find no mention of the problem, from memory it just says "releive bearers to clear tubing" but I can't get into it properly with a Dremel so thought easiest way would be to have the nipple coming out underneath the nose retract. Gary.
well that is would be my poor language ....
anyway what i did was dremel a bit of the former off , exactly where that nipple would rest this should be half down the formers?.
bend the tube 90 degrees put the retract in and the tube will bend itself into a curve again..
i forgot to make a picture of it..
