RE: Retract Problem
In response to your original question. it depends where the cap is sealed onto the cylinder. the cap usually has an oring and if the oring seal is on the top interface between cylinder wall and cap surface, it will leak if you loosen it, if its sealing on the Outside diameter side to the cylinder wall it wont leak. you have to open it and see where the seal line between the oring and the parts are.
hope this helps
Jason
