RE: GLOW TO ELECTRIC CONVERSION
May I suggest an AXI 4120/18 (if your an AXI kind of person) and Castle Creations Phoenix 80 controller on 5s to 6s 3300-3700mah Lipos. Should probably use around a 14 to 16 inch prop. (Not sure if that size prop would work on your airplane though might have ground clearance issues).
Or an Axi 4120/14 on 4 to 5s lipo.
CG should be set per manual, with all batteries installed and ready to fly.
There are many combinations to choose from, just depends on how much you want to spend on it.
