RE: servo
Sorry about the presumtion then. Check all the linkages for the tail servo, belt tension, belt condition, pulley condition, make sure it is all like it should be, nothing loose or worn in the tail drive assembly, and if all that is good, open the servo and see if there are any stripped or worn gears in it. If they are, do a search to see if you can just get the gearset for the servo.
