RCU Forums - View Single Post - 2.4 receiver question
Old 12-27-2008 | 10:37 AM
Zeeb's Avatar
Zeeb
My Feedback: (41)
Default RE: 2.4 receiver question
ORIGINAL: Hangar_9_Guy
I have a world models nemesis 52 and a hangar 9 twist 150 that needs receivers (2.4) I was looking at Spektrums AR6200 and AR7000 Other than size, are there any real performance differences here? Or, as long as it's full range, what other receivers do you guys recommend for 2.4? I'm using the JR X9303 radio/transmitter.
Well I'll try and clear up the issue for you;
Both the 6200 and the 7000 are full range rx's, just one is a 6 channel and the other is a 7 channel.
With the exception of the new AR5000, all the full range rx's have at least one satellite rx. The new AR5000 is also full range but has a slightly different antenna arrangement than the other full range rx's and it is 5 channel. The little rx's other than the AR5000 like an AR6100 without a satellite rx, are defined as Park Flyer/small electric type rx's.
Any Spektrum/JR 2.4GHz transmitter with the exception of the DX6, can run any Spektrum/JR 2.4GHz rx. The DX-6 can only run an AR6000 rx, but your X9303 will even run that older AR6000.
Does that help clear things up for you?
