RCU Forums - View Single Post - VQ A6M5 Zero Build Thread
Old 12-28-2008 | 12:26 PM
juggernaut47201
Default RE: VQ A6M5 Zero Build Thread
Well, had a chance to glue the wing halves together. I trial fitted everything before applying the Epoxy. The wings of this ARF were well made and everything fitted together nicely. I used masking tape to protect the push rods, keeping them from being glued. Applied generous amounts of Epoxy and pulled the wing halves together. I used cloth pin, binder clips and rubber band to pull the two halves tight while the Epoxy cured.
Of course use rubbing alcohol to clean up the access Epoxy oozing out of the joint, and applied tape to the bottom of the wing keeping the Epoxy from oozing more as it cures.
ID:	1098112   Click image for larger version
ID:	1098113   Click image for larger version
