 VQ A6M5 Zero Build Thread >
Old 12-26-2012 | 07:07 AM
  #126
Default RE: VQ A6M5 Zero Build Thread
ORIGINAL: gixxerjack
I've had 2 Zeros since my last post. I've used electric retracts in both and they held up very well. My first Zero is a pile of balsa but my second one is ready to recover in something other than the 'shelf paper' used by VQ. Other than than, it's a big hit at the field and flies well.
Jack, how did you handle the batteries? Are you taking the wing off to insert/remove the packs? Are your 5S packs up against the firewall? What CG are you flying with?
Also, which electric retracts are you using?
thanks in advance!
Old 12-26-2012 | 07:35 AM
  #127
Moose,
The 5S batteries are right up against the firewall. I used thick foam (about 1/4 inch) to cushion the batteries against the firewall. Unfortuantely, I do have to remove the wing to swap batteries. It a slight pain but not bad at all. I used the NitroPlanes/Hobby Partz retracts. The Hobby People ones are the same. I would use them again because there is no real set up and there is aggrevation with a retract servo. I just couldn't get the servo linkages just right and they would always bind and I would hate to ruin the plane because of that. So I used the e-retracts. I understand that E-Flite makes agood pair as well. As for the CG, mine was as printed in the manual. The Rimfire .46 and the 5S balanced perfectly. I did use stand-offs to make the cowl and motor line-up correctly. Another flyer at the field did not and he had to add A LOT of weight up front to get it to balance. I hope this helps.
Jack
Old 12-26-2012 | 07:47 AM
  #128
Jack, thanks so much. It turns out I already have a pair of these:
http://www.hobbypartz.com/77p-91-ere...-onepiece.html
and I got the struts from VQ, so I should be good there.
I have a Scorpion 4020-10 for 5S...now I just need to figure on a prop, but that can be decided later.
I'll probably use an Arm Safe type plug and run an exterior balance extension so I can charge with the pack in the plane.
thanks again for your help!
Old 12-27-2012 | 10:44 AM
  #129
Am I missing something? My rudder is already glued to the vert stab. Why would they do that at the factory when you need to insert the tail wheel assembly?
Old 12-31-2012 | 05:57 AM
  #130
That rudder assembly shouldn't be glued According to the plans that I had you have to install it after that tailwheel it's installed.  I have successfully removed those hinges after I crashed one so it can be done. Let me know how it goes.
Old 12-31-2012 | 06:01 AM
  #131
Yup, I had to cut them and re-hinge them, no biggie, just extra work.
