RCU Forums - View Single Post - FSone program closes
Old 12-28-2008 | 08:56 PM
agapetos
Default RE: FSone program closes
hugger thanks for your reply about me starting up with a new beginner heli!
It can be a bit tough to troubleshoot this without being at your pc, but I will throw
a bunch of things to check/try your way and see what happens:
1: make sure your nvidia drivers are digitally signed and have the newest version NOT from microsoft updates,
but directly from nvidias website.
2: uninstall the program and make sure to disable your spyware protection and virus protection when you install.
Restart the pc imidiately after and double check your virus and spyware protection is on.Many times these will prevent certain scripts
from being written and mess up the install.
3: once you run the program, check the setting around video and see if it has safe mode video settings.
Some video cards don't handle certain shading, anti-aliasing and so on.
4: if this does not work, hit cntl alt delete and hit performance and see if something is taking up all your memory or cpu power.
If something does, go into processes and find it, and you'll need to find out what that's all about.
5: also in your video setting within the software, make sure you are using hardware rendering. Does the software recognize
your video card??? sounds like software rendering to me.
6: make sure you have no virus and malware. if you have none you can dl avira antivir which is free and google also malwarebytes, which also is free. they will clean you right up. Don't have two anti virus programs running at the same time.
I think this is good for starters, any questions just ask.
Mike
