RE: Onboard cameras on my RC stuff.
wish I can see the video for the link seems to be incomplete. Anyhow did you keep your video TX far apart from the speed controller? Did you power the video and A/V TX on a seperate battery? Reason for that on is if you share the same power source and did not isolate the noise properly, then you will see noise on the video. Simplest way is to just power the camera and A/V TX on a seperate lipo pack. Again... keep the TX far-far away from the speed controller and RX. Good luck!
