RCU Forums - View Single Post - Flight Simulator Recommendations...
Old 12-29-2008 | 12:55 PM
Witterings
Default RE: Flight Simulator Recommendations...
ORIGINAL: twoslick2
Yes, I have some paper instructions and I noticed when I was loading the cd that it asked for what lanuage I wanted and I expected a tutorial. I have calibrated the TX. Now I am looking for some help to get started . I need some basics to get me started.
There's really not much to it, go back into where you calibrated and check the channels are set up to work with the correct sticks, when you're in that box on the left hand side it should read the numbers from top to bottom 4, 2, 1, 3, 4, 2, 1, 3 and the box just to the right of this with Inv written above all of them should be ticked the whole way down from top to bottom.
If you have to change any of these should re calibrate it.
Press i to to take off and you're away, the left hand stick up and down should be throttle and left right should be rudder easiest to check rudder on the ground and the right hand stick left should bank the plane to the left and right to the right and pulling the stick back towards you the plane should climb and push it away from you and it'll descend - if you crash press i again it really is as simple as that.
If it's totally your 1st time of flying you can press C which will put you into follow mode and get you a bit used to the feel of the sticks but as soon as you can you want to stop doing that as it doesn't give you a real feel for flying nor the orientation of the plane coming towards you.
If you want to change models press the F2 button at teh top left of your keyboard and double click on the model you want to change to.
If you have any further queries just let us know !!!!
