hey I was wondering what was the differential part that you got when you installed your fantom. a part number helps. also is this the kind of wheel I should use to cut the shaft?
http://www2.towerhobbies.com/cgi-bin...?&I=LXE268&P=7
also when you cut the shaft wouldnt you cut the flywheel pins off???
thanks a bunch
