RCU Forums - View Single Post - FSone program closes
Old 12-31-2008 | 02:03 PM
leadtongue
Default RE: FSone program closes
run dxdiag on your computer and make sure you have hardware acceleration enabled. just go to run and type in dxdiag and hit enter. also i had to enable verticle sync as the sim requires it else i get a slight ripple effect while flying. i have antialiasing set to let application decide... same for anistropic filtering. also overlooked... make sure you are running 32bit color! 16 bit will cause havoc.
