RCU Forums - View Single Post - ct5 cambers
Thread: ct5 cambers
Old 01-01-2009 | 07:25 AM
DanBP
Default RE: ct5 cambers
You need to have a softer suspension for the back, an probably 1 or 2 degrees in for camber, you'll probably need to take the bottom out and bring the top in (stock set 5mm top 6mm bottom, you want 4mm top 6.5-7.5mm bottom) like a 15 weight shock oil will help too.
