ct5 cambers
NY
hello can you adjust the camber on the ct5? was it made to do that? i have a problem with my rear tires no sticking to the ground and i thought maybe if i adjust the camber on the rear it would work. can that help?
You need to have a softer suspension for the back, an probably 1 or 2 degrees in for camber, you'll probably need to take the bottom out and bring the top in (stock set 5mm top 6mm bottom, you want 4mm top 6.5-7.5mm bottom) like a 15 weight shock oil will help too.
