RCU Forums - View Single Post - Saito 125 poor performance problem
Old 01-01-2009 | 09:12 PM
  #102
gkamysz's Avatar
gkamysz
My Feedback: (19)
Default RE: Saito 125 poor performance problem
ORIGINAL: chashint
You asked how much oil came out of the vent port.
The fuel tank is 360 cc the bottle is 500 cc.
The engine is 300 rpm fat at WOT, the LSN is set as lean as possible to have good quick transition to WOT.
50% of the tank was run at WOT the rest was run at mid throttle and maybe three minutes at idle.
I would guess a little less than 1 oz is in the bottle (29 cc).
That's rather interesting. Assuming 20% oil, there was 2.4oz of oil in the tank. ~40-50% of that made it past the ring into the crankcase. This assumes the crankcase was already at the average running oil volume and that there was no extra oil in the crankcase, such as after run oil. That's actually quite a bit more than I expected. In that case, I think we could run much less oil than we do in four strokes.
