RCU Forums - View Single Post - SPE 40cc
Thread: SPE 40cc
Old 01-02-2009 | 04:26 AM
  #278
reynolds74
From: Povoletto (Udine)Friuli Venezia Giulia, ITALY
Default RE: SPE 40cc
ORIGINAL: tkg
BCCHI Anyway with RCEXL ignition timing should be set 28 to 30 degrees BFTDC. As with most all gas two stroke engines .We can set 32 to 35 we are at 5500 ft elevation.
I have an SPE 40, and hopefully I will break-in and fly it at the end of January. I'm also planning to buy a RXcel CDI for it. You said 28-30 degrees BTDC. This means regardless when the CDi actually gives a spark? Or do we need to consider 28-30 degrees BTDC when a spark occours?
I'm planning to buy a 28% SU26 77 inches but I'm not sure if the SPE40 (I will also upgrade with WT540 carb, I bought one sometime ago...) will be enough for good 3D aerobatics.
Andrea
