Comp Arf Flash. Help.
Hi Guys,
Just started building my Flash and the build is smooth so far. I do not plan to fit the bypass as i plan to install the new wren 160 in there.
My question for those who are flying without the bypass is whether they have installed the inlet joiner up to the engine, or is there no use for the inlet joiner to be installed, and the pre installed intakes are good enough for a non bypass set up.
Thanks.
Best regards
Chaitanya.
