RCU Forums - View Single Post - Deception 10 Build Thread
Old 01-02-2009 | 06:45 PM
  #61
doxilia's Avatar
doxilia
Default RE: Deception 10 Build Thread
A few images should tell the story.
Carbon tape applied to top and bottom. Laminated wing cores drying overnight. Resin smoothed out with alcohol applied to the retract pushrod foam tunnels to seal and provide a running surface for the rods. I might add outer shafts to the rods to keep the spacing snug but probably not needed.
I think I have about 100 lbs on it - perphaps a tad too much
David.
ID:	1101876   Click image for larger version
ID:	1101877   Click image for larger version
ID:	1101878   Click image for larger version
ID:	1101879   Click image for larger version
ID:	1101880   Click image for larger version
