RE: VQ A6M5 Zero Build Thread
In practice I have found the mounts to just pull square under pressure.
They are not great but I have Saito 72's and even ASP 91's hanging off them with no problems.
The GRP is flexible enough to 'square off' under the pressure from the mounting bolts.
But you have to careful not to do them up too tight or you will create more distortion.
