RCU Forums - View Single Post - Pershing Problems
Old 01-03-2009 | 04:51 PM
YHR's Avatar
YHR
Default RE: New heng long pershing, peculiar problem?
ORIGINAL: miniz33
Thanks guys, the motor problem was a simple fix, I wired the motors to the opposite connectors, so motor one was running off of wiring for motor 2, and vice versa. I took a few hours today to work on other issues, like the track alignment, the damaged pins etc. I also got around to weathering and adding a few scale accessories to it! I have to say I'm pretty much hooked on it now that it works, this thing runs like a bear; I cant believe the torque of this brute, it'll go over anything!
EDIT: Every ten minutes of driving a few pins start to come out, is this normal? Its driving me to the point where I might just go with a weighted plastic track..
Take the tracks off and spray the inside with a rattle can of some "texture" type paint. You can buy stuff that has a metalic finish This layer of paint will keep the pins from coming out. I have to say track pins coming out of a Pershings is pretty unusual. That is the one tank I never have a problem with in this reguard.
