RCU Forums - View Single Post - Out of Alignment !!!
Old 01-03-2009 | 07:05 PM
Popriv
Default RE: Out of Alignment !!!
I'm supposed to place the fuse over the wing to get the position to drill the holes in the TE of the wing.
Then I glue the floor of the cockpit in place. like you say, this may straighten things out as this looks like the area in question...
This is what I was doing when I started noticing the alignment. I was reluctant to drill the hole locations in the TE the way things are lining up????
I'll see what happens with the cockpit flooring in place with rubber bands. If I do glue this in place first I'd have to figure out how to get the hole location for the trailing edges of the wings. Or drill the holes then put the flooring in and see if it straightens out???
Ken, If the fuse was complete would these angles concern you???
Seems pretty far off if this is what I end up with?
Steve
