Bottom work...
Wells begin 90 mm in and run for 112 mm. First cut... very slooowwwwly...
Servo wells centered at 235mm along CG line just forward of front gear plate. Make littlest hole possible - hollow - good, we're in.
Ailerons & elevators, here we come!
Tack glue, sand to contour, mark aileron line. Next, tack glue tips, sand to contour and pop off. Hollow tips, glue permanently.
Pop off TE, cut ailerons, glue center TE portions, hinge ailerons. Bevel ailerons. Wing done! Follow suit with stab.
We're almost there.
David.
