Mixing for newbies learning ( should I ?)
I ended up watching a copy of a video called "Solo in 7 days".. I have to say, the landing info really helped me on landing using the Simulator program by using myself for the landing target and performing the downwind leg of the landing pattern.. I hit the runway every time now instead of always being off to the side.
It shows using a Y-harness to control the Rudder and Ailerons together at the same time to control Adverse Yaw.. In the video the affects of adverse yaw are very apparent.
My question is whether, while learning , I actually should use the mixing on my Radio to control Adverse Yaw? It appears to me as if you would not learn to use the rudder with mixing set to control the Rudder and Aileron's together.
