RE: Correct angle of motor shaft in a pusher.
This is a GWS f-15 converted to a pusher, with a center line drive shaft setup. Never did one of these before. Lost on it.
GWS has a moulded in stick mount slot that angles left. It is for a 1" above centerline mounted pusher. The slot is highlited in black marker ink. You are looking at the bottom 1/2 of the fuselage.
Do I need to play around with moving the shaft off of the centerline. My maximum speeds level would be 40 to 60 mph.
Rich
