Go Back  RCU Forums > RC Airplanes > Aerodynamics
 Correct angle of motor shaft in a pusher. >
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Old 01-04-2009 | 09:11 AM
cyclops2's Avatar
Default Correct angle of motor shaft in a pusher.
Which directions should the motor in a pusher be moved to when looked at from the rear ? L / R and the U / D.
GWS has the motor shifted to the left of centerline. Is that correct ?
Rich
Old 01-04-2009 | 12:38 PM
w8ye's Avatar
My Feedback: (16)
Default RE: Correct angle of motor shaft in a pusher.
The motor shifted to the left of centerline on the mounting but is actually canted towards the right by 2 degrees
Old 01-04-2009 | 01:08 PM
cyclops2's Avatar
This is a GWS f-15 converted to a pusher, with a center line drive shaft setup. Never did one of these before. Lost on it.
GWS has a moulded in stick mount slot that angles left. It is for a 1" above centerline mounted pusher. The slot is highlited in black marker ink. You are looking at the bottom 1/2 of the fuselage.
Do I need to play around with moving the shaft off of the centerline. My maximum speeds level would be 40 to 60 mph.
Rich
Old 01-04-2009 | 02:49 PM
BMatthews's Avatar
It doesn't look like there's a universal joint at the back end so you won't be moving it in any direction enough to make any difference. Just go for the smoothest possible operation and be happy. Also I'm going to assume you know that your prop is on the wrong way to work as a pusher.....
If the motor itself was back at the tail then you could make effective thrust line changes. Downthrust at the back is still downthrust since the idea is to pull or push the nose down to counter the natural tendency to climb as speed increases. Right thrust is a little different if you need it. On the nose you'd set up the motor with the right prop tip pulled back but on a pusher the right side prop tip would be pushed forward to get right thrust. The thrust line works like a rudder when it's at the tail.
There's no magic to setting up a pusher for thrust angles. Just look at it and imagine which way the offsetting will move the tail. If it helps think of the motor being turned to 90 degrees in any given direction and what THAT will do to movement at the tail. Obviously you wouldn't use that much or anywhere near it but as a visualization aid it should help.
Also good luck on getting that long a shaft to operate without a lot of wobble and slap. Or drag in this case since if it flexes due to prop issues the shaft will rub on the foam. I foresee some melted foam in your future. The motor and prop would run MUCH MUCH smoother if you mounted the motor at the rear with very little extension to the prop. Long shafts that are rigidly mounted at the ends are not good options for power transfer when run at high speeds with slender shafts and big flyweights at the end.
Old 01-04-2009 | 04:03 PM
cyclops2's Avatar
This one is good.
Thanks for the pusher offsets.
Rich
ID:	1103481   Click image for larger version
ID:	1103482   Click image for larger version
ID:	1103483   Click image for larger version
Old 01-06-2009 | 05:31 PM
I have a Balsa USA Enforcer and every time I would power up the plane would nose down. I ended up putting a lot down angle in the engine mount, so it would push the back of the plane down (and therefore the nose up) when applying power. I didn't notice any right/left offset angle.
Andrew
Old 01-06-2009 | 07:21 PM
cyclops2's Avatar
Thanks Andy.
2 opinions that agree.
Need 1 more for a medical release.
Rich
