RCU Forums - View Single Post - Extreme Flight Yak 55 good for learning 3D?
Old 01-05-2009 | 10:00 AM
KWJ48's Avatar
KWJ48
Default RE: Extreme Flight Yak 55 good for learning 3D?
The Chinn yak flys loose, and the fuse is a little more fragile than other profiles. Not to good for learning and dorking in the ground. If you're just starting out I suggest a mojo 40 or omp edge v3. Either one will be easier to learn 3d than the twist. IMO
