RE: Tiger 60 Build Thread
[font="Arial"]Hi Guys-
One more question if you all don't mind-
The plans call for 2 degrees down thrust and 2 degrees right thrust. I have read elsewhere that some folks use small washers under he motor mount screws to accomplish this, with one washer being about one degree of movement.
Does that sound about right? Are there other ways to get the proper thrust angle? Can the thrust angle be readily measured.
Again, thank you all for the help you have provided.
Larry-
still sandingbut getting closer to calling it ready for covering!!!![/font]
