RCU Forums - View Single Post - DA-50 throtle exponential curve
Old 01-06-2009 | 06:43 AM
BaldEagel's Avatar
BaldEagel
Default RE: DA-50 throtle exponential curve
I have found the easiest way to set up the mechanical linkage is to set the servo arm pointing straight down the throttle pushrod at fully closed (stick and trim fully back), this will give a good starting point for fine tuning the curve if neccessary.
Mike
