RE: Unionville Beaver 8' Kit tips
I'm just about to start one and one thing I'll be changing is the wing mount system.Order in a set of SIG wing joiner blades so you will have strength as the wing struts,as designed,are functional.This way it also makes it easier to put together at the field and if a strut should fall off,you will save the plane.Also,I'll be sheeting the wings and fuselage as well as mounting the servos in the wing panels.
Ian Gunn
MAAC 25307
