RE: Deception 10 Build Thread
Gd'evening readers,
I spent a little time at the LHS this evening. With some fresh wood stock in hand, I'm able to head back to the work bench! I found some nice mahogany 1/8" square strips - excellent for control surface trailing edges. I also picked up a K&S 1/8" OD aluminum tube which conveniently has an ID of 3/32". This tube will be used to couple 1/8" wheel axles and equivalent wheels to 3/32" retract struts - a nice snug fit!
I actually found all kinds of treasures. I decided to pick up a couple of rare finds: 2 MK nylon props - an 11 x 7-3/4 and a 12.5 x 8. I'm not sure what it means but they are designated as +2 props - I think it has something to do with the noise factor. The 12.5 x 8 should be an interesting prop on a YS AR or an OS Hanno! There were also a plethora of discontinued Graupner props in all kinds of sizes.
Wings await...
David.
