RCU Forums - View Single Post - Sig Hog Bipe - Build Thread
Old 01-10-2009 | 03:17 PM
  #373
SeamusG's Avatar
SeamusG
Default RE: Sig Hog Bipe
MA - lookin' good mon ...
When you build your covering panel what's your technique for ironing the pieces together? How much overlap? Do you start with the piece closest to the tip / trailing edge then overlap it (and each subsequent piece) with the inner / more forward piece continuing until you reach the center / leading edge? How about the iron? A big one or a trim iron? Temp? (I know that monokote and untracote have different heat ranges). Do you use any kind of guides that hold the pieces flat at the seam?
Enquiring minds are a dangerous thing!
Cheers,
