RE: CEN FF servo question?
Disconnect the linkage from the servo arm and see where its binding.. most likely its in the ackerman arm.. maybe a nut or bolt hitting the chassis or one of the linkages is not set the same as the other side.. there are not alot of parts on the steering system, so its a process of elimination..
