RCU Forums - View Single Post - What would be the next step
Old 01-11-2009 | 05:09 PM
hedach
Default What would be the next step
Hey guys. I have a Miss Vegas that has reached consistent 60mph runs with a best of 60.8. I run a NEU 1521 1.5d motor, Two 4900 mah 11.1 batterys, and a Octura m545 modded. The hull has been modded ,bottom has been cut and is flat. Prop is extended 2.5 inches back. It has a very short rudder to reduce drag and short turn fin. I have tried 9 different props and this prop has pruven to be the best. Run time is great and for just messing around i will run two 7.4 volts with even better run time. My goal has always been 65 mph but no matter what i do she will not pass the 60 mark.I know this hull was not ment for this but its cheap, especially when it crashes,losses radio contact wich is always a good time LOL and hit a few things so finding them on ebay is easy and cheap. What do you think my next move should be. Mabe a custom prop? 50volt esc and more voltage batterys? Thanks for your time
