RCU Forums - View Single Post - Testing a Magneto system ?
Old 01-12-2009 | 12:56 AM
Ram Jet's Avatar
Ram Jet
Default RE: Testing a Magneto system ?
Mags are pretty simple. Condensers seldom give you trouble, check the points making sure they are gapped correctly. I don't know what resistance reading you should get across the primary coil windings but if you don't get some reading you have an open circuit and the coil is bad. There's a remote chance that the permanent magnets in the rotor may need to be remagnitized - if there is a shop that still does that.
Bill
