RE: Testing a Magneto system ?
A Zenoah G26 does not have any points or condensers. Most likely the gap between the magneto and the coil is too wide. That gap should be about the thickness of a business card.
What did you do with the black wire comeing off the coil that was not connected to anything? You refered to this in another post, disconnect it from everything and see if the engine runs.
