RE: Blade CP
Got some info from E-Flite tech guys.
I asked them about using a normal transmitter with there 4 in 1 receiver. They said that they never tried it but it might work.
The receiver is a neg shift, so Hitec Eclipse 7 and Futaba computer transmitter should work. There crystals are single conversion.
Since this is a 6 channel receiver you may need to mix channel 3 and 6 together to to get the throttle and pitch to sync together.
The only thing I need to figure out is the arming of the receiver with the throttle control. So far I have not been able to get the receiver to arm itself.
Larry
