Nose Ring and Hyde Soft Mount
Hi guys,
I want to reduce a thrust line movement on my Ultimate 120 with Saito 125. I have Hyde Soft Mount Type HCMYS110A, which does not require a nose ring.
I want to make a nose ring and its supporting frame by myself.
I have a question regarding a position of nose ring
1. The nose ring is holding a not moving part of the engine just before the drive washer.
2. The nose ring is holding a rotating part of the engine - strait above a drive washer gap ring.
Which statement is correct?
If statement 2 is correct one more question.
Does a nitro fuel tube, I'm going to use as a rubbing material inside the nose ring, supposed to touch the rotating drive washer (when engine is not working). If no what is a gap?
Any advise is appreciated.
Thx
