Nose Ring and Hyde Soft Mount
Old 01-13-2009 | 01:53 PM
eclipse3g's Avatar
Default Nose Ring and Hyde Soft Mount
Hi guys,
I want to reduce a thrust line movement on my Ultimate 120 with Saito 125. I have Hyde Soft Mount Type HCMYS110A, which does not require a nose ring.
I want to make a nose ring and its supporting frame by myself.
I have a question regarding a position of nose ring
1. The nose ring is holding a not moving part of the engine just before the drive washer.
2. The nose ring is holding a rotating part of the engine - strait above a drive washer gap ring.
Which statement is correct?
If statement 2 is correct one more question.
Does a nitro fuel tube, I'm going to use as a rubbing material inside the nose ring, supposed to touch the rotating drive washer (when engine is not working). If no what is a gap?
Any advise is appreciated.
Thx
Old 01-13-2009 | 02:07 PM
Default RE: Nose Ring and Hyde Soft Mount
#1 will be the correct place. Looks like you will need to file the front part of the fins to get the space. Good luck,
Vicente 'Vince" Bortone
Old 01-13-2009 | 02:15 PM
eclipse3g's Avatar
ORIGINAL: vbortone
Thx Bortone.
OK. That's Saito . YS & OS have no those fins.
Old 01-13-2009 | 02:40 PM
Well, looking closely you have the cam housing also. I am not sure if you have enough space there to fit the nose ring. If you mount does not require nose ring I sugges not to install nose ring. Is the mount very old?
VB
Old 01-13-2009 | 02:59 PM
eclipse3g's Avatar
ORIGINAL: vbortone
VB
I've just bought it. Nothing to do during Winter time and that idea came to my mind. May be you right, just leave it how Hyde said - "Type A doesn't require a nose ring".
Old 01-13-2009 | 03:14 PM
OK. I got the impresion that you were having problems. I am using one Hyde mount of the same type in a DA100. More than 200 flights in that plane with no problems. You need to look for another project and leave the mount alone.
Good luck,
VB
Old 01-13-2009 | 03:21 PM
eclipse3g's Avatar
Thanks to everyone who participated in this discussion,
I think the topic is closed. No nose ring is gonna be placed on HCMYS110A mount.
