RCU Forums - View Single Post - Diffs on RC8T
Old 01-13-2009 | 06:08 PM
losi101
Default RE: Diffs on RC8T
ORIGINAL: ofna_kyle
My question is do you have to take the front, center, and rear diff apart to add grease or are they good. The manuel says just add 7000 fluid and your good to go and people that have wriiten reviews about the truggy say you just fill the shocks and diffs with fluid and your done. If grease is needed to be added, how much is needed? This is my first build so all advise is accepted. Thanks.
Grease? No grease. Start here with the diff oils. 7 front 10 center 5 rear. make sure you use diff oil and not shock oil. You will have to take the diffs apart. Fill the diffs up to the top of the gears and your good.
You sound new the RC world so I would leave the shocks alone. They already have oil in them.
