RE: Element 170 ARF wood Versions are in
The OS-160 with the mueller header is what I used on all mine with the OS pipe for the 140RX,..works great! The other pipes will work great as well,..it should be a fairly easy set up. Order the header pipe from Karl for the Icepoint as the Icepoint was on a rail mount system and it shoud fit just fine.
Best Regards,
Bill H.
Team Fliton
