ORIGINAL: Idare2bdul
The only problem with flying more responsive planes in the sim is that sometimes you want your plane to do something and you don't have time or altittude to pull it off with the real plane.
Except with a real plane you should never try a new stunt anywhere near the ground in the 1st place but should be at least double the height and then add a lot more than you think you need then when you know how the plane responds and how easy you find it to do you can start coming lower.
The 1st time I try anything new I go way way up high so that even I get it more wrong than I could possibly imagine I've still got plenty of time to sort it out and bear in mind a Sim is a great tool but it's not the real thing !!!!!
