RE: Dumb building question (titebond vs CA)
This is my first build with wood glue. All the other times i've used CA and it is a bear sometimes when something is not glued straight or CA runs all over the parts that need sanding. I just completed one wing panel on a SS60. My method was to setup all the ribs with the spars, leading edges and trailing edges pinned. I zapped them with alittle CA and let it set for a second. I then used Elmers wood glue to add all the sheeting. That way the parts that are going to be sanded do not have CA on them. Working good so far.
skeeter
