RCU Forums - View Single Post - MiniMag... on glow!
Old 01-15-2009 | 02:29 PM
Patxipt
Default RE: MiniMag... by OS Engines
Mounted the ASP 12A on the MiniMag, just had to widen a bit the wood mount with an x-acto knife. The 12A has the width of a OS 15 and mounting dimensions of a OS 10, funny mix
Fire the engine up, by hand, and it didn't take much to start, considering it has been on the shelf for 5 months. Plenty of power, doesn't lug down like the 10LA when the nose is down, nor speeds up when pointing the nose upwards. Can't wait for the weather to clear up to give it a try.
Forgot to mention the landing gear support broke on one side on the last landing. The plane was perfectly aligned with the runway, but as I was a bit far from it, it missed the runway by 2 meters to the left side, hitting a drainage channel and soft ground. Nothing like a good old hand launch and soft ground belly landings won't sort out in the future
