RE: Element 170 ARF wood Versions are in
The Element 170 mono-wing version will accept the DB mount for the a two stroke only. I would not remove the rails entirely, as it does provide some strenght to the front side walls. You can use a Hyde mount, but you will have to cut away some material off the rails near the firewall and shave it else where to get it to fit.
Best Regards,
Bill H.
Team Fliton
