RCU Forums - View Single Post - Saito 125 poor performance problem
Old 01-16-2009 | 08:42 AM
  #115
DarZeelon's Avatar
DarZeelon
Default RE: Saito 125 poor performance problem
ORIGINAL: highside
I've just dropped a YS FZ1.10S onto the test-bench, same fuel (15% nitro, 20% klotz)...
HighSide,
The YS is very likely to run badly on that fuel...
Unlike OS (and its clones) and Saito engine, that will run nicely on fuels containing 15% nitro (or even less), YS engine require 20% nitro as a minimum, to run as intended.
They are designed for high nitro percentages, rather than this being a convenient option...
Also, are you talking about Klotz Techniplate?... Knotz BéNOL castor oil is not the ideal oil for a YS. 2% of this oil is OK, but not all castor, if you want to keep your maintenance to a reasonable frequency...
On 15% nitro these engines may need to be leaned down excessively, to the point of overheating, just to get the proper mixture strength.
I believe the YS 1.40 Sport is their only engine for which 15% nitro is within the recommended percentage...
Testing your 1.10 on that fuel will prove no point.
