RCU Forums - View Single Post - Which connector is needed for...
Old 01-17-2009 | 03:19 PM
lownslo's Avatar
lownslo
Default Which connector is needed for...
I am powering a Sea Queen with a 12volt sealed lead acid battery. I have a Mtronics, Viper 20 ESC. The ESC comes with a Tamiya male plug for the battery. The ESC directions say that if the factory plug is removed/altered/etc., the warranty is void. All I see is 7.2 volts in conjuction with the Tamiya plugs. Will these Tamiya connectors be OK for the 12 Volt battery and my 20 amp ESC. I do have an inline fuse between the battery + terminal and the ESC. I would rather use Deans Ultra .... but........ ????
slowboat ..... lownslo........ Bob in Indy
