RCU Forums - View Single Post - Modeltech Super Cub
Old 01-17-2009 | 06:11 PM
lcacing
My Feedback: (21)
Default RE: Modeltech Super Cub
I just got back from flying and I put about (7) 10 min fligths , I do have a video that Ill put up later tonigth.
WESLEYK
If you are going to se the canopy screws to hold the two wings spar bolts together you will need to get longer M3 screws.
I found that the tail gear set up is crap [:@], after each landing the wheel would turn all the way so I would have to go out and
reposition the tail wheel, I think if you change that wheel collar that secures the wire to the tail bracket it should hold.
EKIR
The 55 will work just fine but if you use any 2 stroke engine it will required a pitts muffler.
